Wicked31
I’m out of ideas so I’m turning to the knowledge of this forum for help.
68 charger 383 auto idling at 850 drops to 500-600 rpms eventually dies if no throttle is added. Installed a 750 street demon since old carter was leaking from everywhere. Checked for vacuum leaksby spray contact cleaner around intake/carb disconnected all vacuum lines and plugged ports doesn’t seem to have any leaks. Adjusted carb with vacuum gauge best I could get was 12-15. Timing set at 12*. Switched to a Holley dp I had laying around same issue. Not sure if there’s an electrical issue that could be causing it, wore out camshaft, transmission/ torque converter issues? Any help would be appreciated. Thanks
