What size bore?
max340
5:55 PM
San Diego
Ok, manual brake car and pedal. I've got the original single piston calipers up front and the SSBC single piston on the rears. I called Wilwood with the specs and two calls yielded two different answers for the master. What bore should I be installing here? I have a 1" from POL and have a totally hard pedal. Should I get 15/16" or 7/8"?? I hope I can stick with just manual and get this done. Thanks
Max, I used the MC that came with the SSBC kit on the manual disc conversion for my 71. Stopping is unsatisfactory. I switched to a 15/16 on my 65 and very happy with stopping and pedal pressure. Way better than my 71.
When you say hard pedal, doesn't that mean it's not stopping well?
The pedal will travel about half way then get hard to push. I can stop the car only because I'm strong enough but that's really pushing.
Ok thanks. I figured I'd get someone with my situation here. I read a bunch but no one comes back with their success story.
These are from Mopar Action disc brake conversion about master cylinders.
