yes you should hear the idle changeIf it was the intake if I spray intake cleaner around the outside and under the intake if it’s a leak I should be able to hear a change in idle correct?
when you do this do it at normal idle then do it at high idle at operating temperature (you know the heat thing)If it was the intake if I spray intake cleaner around the outside and under the intake if it’s a leak I should be able to hear a change in idle correct?
yes I agree those are great numbers. I hope mine comes out that goodThose are great numbers for a street stroker and they closely mirror what I got with my tf240 with Holley street dominator single plane and 499ci. Unless you are getting craziness like white plugs on the passenger side and fuel fouled on driver side, I would not worry. If you want to investigate further and you have headers you can use an infrared thermometer on each exhaust port to get approximate EGT.
NoI just thought of a question not sure if this would matter. I’m running the Holley 850 Xp but I’m running a open gasket with the duel plane intake? It does have the notch center. Could this cause my issue?
Yes exactly.NGK v power plugs? if so I love them if they are indext right
my question is how old are these plugs? How long have they been run before you pulled them?Yes exactly.
I'd try a nice single plane on it and probably never look back. At that many cubes, can't imagine the dual plane is really useful.
How much vacuum do your motors make? I took a reading from the pcv hose and it was about 4-5 but bouncing all over between 0-5. If I brought the rpms up it would go to about ten but still jump all around. The car runs rich at idle and I think it’s because the base timing is at 14 degrees and total is 32, I ordered a 10-14 bushings to try to clean it up. If the bouncing is up and down even with rpm could this be messing with the power valves when driving down the road? Also can I trust this vacuum reading from the fitting going into the #7 runner at the back of the intake?agree! they are defiantly not needed. I’ve ran a lot of different intake/carb combos on my streeter 512. The older smaller single planes give up nothing to the dual plane, and even the big Indy single I ran for a bit was absolutely awesome through the whole power band. The biggest thing I noticed with the single plane is all the plugs looked perfectly even and the idle characteristics are better. If that’s what he’s after the single is the best way to go. That being said I just put my dual plane back on cause I like the look for the car. It’s pretty modified internally at this point though and seems to be working quite well. No matter what intake is used they require carb tuning to get things dialed in.
I agree with the single plane intake on big cube motors. They make big torque on the bottom already and single plane carries it all the way out. I went with an eddie torker 1 on my 512 (440 based) and carry big torque numbers from just off idle all the way through the powerband.I’ve ran dual planes and single planes on mine. I will say the distribution sucks with dual planes on the big motor. I’d recommend an old school single plane like a tm6 or Holley SD even on a street car.
