- 7:41 AM
- Jun 12, 2012
- NZ - just short of the South Pole
Brother of Darth.Chevy Veda?
Front steering - looking at the front of the vehicle......and it is still left hand drive as original.Kiwi, excuse me, I'm slightly confused. (Heck, being only Slightly confused is an improvement).
Is your axle drawing a rear view of a righthand drive, or a front view of a left hand drive? Front or rear steer?
Its all fun steer some do rack and pinion some just do true some do variable ratio.Front steering - looking at the front of the vehicle......and it is still left hand drive as original.
The steering drag link (side to side bar) is behind the beam axle.
Tie rod end on the passenger side.
I looked into this - a system which is much like the Mustangs used. Trouble is, I need a steering gear box with the extra two ports for the ram to be operated as a slave, and since space is a premium, I don't think I can squeeze all that in underneath.How bout a PS system that uses a slave? Ford used them on lots of cars in the 60's. They basically used a manual steering box with that system....
Agreed.Any front steer forward mounted box should rotate the way you want. Size and mounting it are the problems. Any 70s-86 square body Chevy has that box, same box on Dodge trucks of the same area. Drawback is they mount outside the frame and the size may not fit under the floor.
Too bad an old Dakota or newer ram 1500 2 wheel drive rack wouldn’t work.
Thanks !Jimmer....
Gotta say you've got a great username.
I've called my son this for 39 years.
The box in the pic is manual. The power steering@Dan64 - I think I can see, but can you confirm that this steering box is manual?
Thanks.
It's not mine,I can't find any close up pictures of the one i just sold but i'm 99 percent sure it's manual, power Vega boxes are not widely used and almost never used in a small/ mid sized hot rod builds. My only experience with Vega boxes are in light weight Model A's.@Dan64 - I think I can see, but can you confirm that this steering box is manual?
Thanks.
Lol, my buddy in H.S. had gm's twin turd, the Sky Hawk ("Skank Chicken"). Yeah, it was a even slower version of a turd barrel.I had a 1978 Oldsmobile Firenza with a Chevy 305 that I bought new for my wife to be. It was single handily the biggest piece of crap I have ever owned. They were prone to control arm problems due to the fact it was a 4 banger Vega setup with a 305 and that THM-200 Transmission was totally useless. I built GM for years because everything for them is dirt cheap and could be found all over the place. GM had their share of thrown together garbage. It was about as refined as the 350 diesel they came up with!
