Small block Torque Converter
chargerrt340
6:33 PM
SoCal and SoOr
So I bought a 408 stroked 360 from Performance Injection Equipment during the heat of COVID. Had them add a TOrque converter to the build……
After a little while I’m finally installing…. Trying to put the TC on the stock sb 727 it looks like the shaft on the TC won’t go over the splined transmission shaft into the trans… the stock shaft is about 1.5” and my new custom TC is 1.75-2.
It’s rated at 482 hp and 530ish torque. How long do you think the stock TC will hold up if i reinstall?
Any advice? Is it the wrong TC? Big block maybe?
There are two different spline counts on convertor depending on the year = think it changed about 1967.
The 904 and 727 have way different size imput shaft. Are you sure you
have 727? Block Big and Small have the same convertor with 727.
The shape of the pan gasket will tell you easily what you have
If you have not done it before = It is tricky to get convertor all the
way into trans front pump. Spin it slowly and Gently tap it - you will feel
the pump drive and splines engage
I an Racing in Pomona Cal. next month and could come figure it out for you if you are anywhere near there.
The black TC with the bigger shaft is the new one. The blue one with the smaller shaft is the stock…..
3B5EF4E8-7029-4FB2-9F6D-495629A68242.jpeg 47EE6D6E-9B8C-4AE5-BA2B-01C708DEC969.jpeg
I can’t even get the TC to enter the transmission seal area. 1st step if you will. If it’s supposed to be tight I’ll do it again with more force, but because there is a 1/4” size difference I’m thinking it the wrong TC.
Blue one IS a 904 Convertor
Aftermarket on IS 727
NOT COMPATIBLE!
You have a 904
Sorry to be the bearer of Bad News = They will NOT work together!
You need a 904 Convertor
Might be cheaper to get a different convertor.
Nothing wrong with running 904s = We do
Goggle: John Irving
All of the 10 sec. small block run 904 - take less JP to operate
OR I have 904 Hi stalls = Maybe we can do some trading
