Currently i’m troubleshooting a Plymouth GTX from 1968, the car is running and driving smooth for 30 seconds. after that the engines runs so rough that it will shutdown itself after hesitating.
The first thing I have tested was the battery and tried my second battery, booth were fine, then I noticed while running the engine, the battery I not charging at all.
Unplugged all the wires, cleaned small corrosion and checked all the fuses, that should be ok now, but was not the problem.
I have tested all the ground wires, smoothed them up, but they were still ok.
Then the alternator came to my mind, i checked all the belts (new) and they don’t seem to be to tight, started the engine, checked if the pulley from the alternator is spinning, it did. After that step I went in with the multi meter here are the alternator results:
(Engine-Off)Battery 13.3 V
(Engine-Running) Battery 12.5V (not charging)
(Engine-Off)Alternator 11.7 V
(Running) flipping between 0 V and 9,5 V very fast
I could not test the other 2 wires on the alternator because the wires from multi meter were not long enough.
Any thoughts? Maybe the volt-regulator or seems clear that the alternator is death..?
