Hemi Scoop OPINIONS needed!
IMO stacks through the hood, and through a scoop is redundant. Skip the scoop.
What pics do you need? all our cars are home for a indoor car show this weekend.
I think a lot of the stack injected nitro cars were made from hemi package cars that would have had a scoop. They just punched a hole in the hood for the injection. I could live with the hood either way, but i think a scoop with a hole for the stacks is probably more correct. (As if Anybody knows what's "correct". I sure dont. I believe in doing whatever you want to your car.)
I bought one of his scoops and I'm very happy with it. I purchased the lower version as you can see.
It has several tabs bonded around the perimeter which have studs so it bolts to the hood... not bonded. For the price I found it to be pretty good quality.
Fit was good right out of the box but I spent an hour or so massaging the edges so it fit perfectly. It also has the correct curve for a '64-'65 hood. The underside was raw fiberglass, however I took a little time to smooth the area since I'm going to add a graphic to that section.
Here's a shot of the scoop after primer. Over all, for the price its a pretty good value.
That looks like the one to me!
Seriously it looks great.
On the taller scoops, you need a really good mounting system like I have on my Sled City Scoops. Little angle brackets are ok if you are keeping your car on the neighborhood streets, but if it is a performance car, check out my hemi scoops on ebay. I am oldwoody426 on ebay. I am the only one out there that has a warranty against cracking or blow offs.
I’m looking for a taller (3.5”) hemi scoop for my 64 Polara. Where can I see your sled city scoops? And how much do they run?
$300 for the scoop and $50 for the ride. If you would like to know more, please pm me. I have plenty of pictures that I text all over the place.
Ok thanks. Yes I would really like to see some pictures. Overall pictures and the mounting flange. Also if you have any pictures of the 3.5” installed. I’ll try to call you later today
I believe we just talked by phone. Thanks.
