MoparMilitia
Hello all, Happy Friday!! Have a weird one, or maybe not. so i just swapped a 8.75" into my 71 b body, and everything went well. i have two cases, a factory 741 with 2.71 gears, open center and a 489 thats currently being built with a truetrac and 3.23's. so i tried the 741 case just to move the car around for the time being, popped it in, slid the axles in, bolted everything up, tires on. went to spin the pinion and... nothing? no rotation on either side tires. Yet, if you put the car on the ground in neutral, and roll it back and forth the pinion does spin the corresponding direction... im wating on a buddy to bring me a Moog 372 U joint (7260 to 7290), so i have no engine power to the diff just yet. is this normal? i would think with most open diffs atleast one tire would turn with input on the pinion... what could be the issue? when i had the 741 center section out everything spun normal, spider gears are moving, nothings blown... is there something in the carrier that could be chooched? im at a loss...
