SOLD 72 satellite Sebring plus project
Moparmatt72
12:49 PM
Nampa, Idaho
Feedback: +1 / =0 / -0
I have my 72 satellite that I won't be able to get to since taking on a 67 dart. It has a 440 bored .060 with good meat left on the cylinders, head and mains studded, 11.5:1 ratio hyper pistons, CAT h beam rods, factory steel crank all balanced, Isky 292 cam, degreed in, dual roller timing chain,440source stealth heads with CAT 1.7 rockers, home gaskets matched, M1 intake with a 1050 Dom. Hooker supercomp headers, flanges removed and install v band, have the other side and clamp. 440 source oil pan and water pump, housing is aftermarket aluminum, 100amp alternator, Griffin dual pass rad. Only have one 12" fan was going to install another, b&m oil cooler and trans cooler. Dual Oil filter relocation kit. Trans is a 727 warmed up can't remember what's all in it but had the red bands, J&W reverse Manuel VB, Hughes 3500 stall, 440 source sfi flex plate, no drive shaft, Dana rear end taken out of a truck, new end tubes, 4:56:1 gears and a locker, strange drag rear disc(not plumbed). Have fiberglass door for it from US body, no front fenders,hood or deck lid, have satillite grill insert, decent shape, rear tail light lens okay condition, has painless wiring 8 switch panel just holding on to the windshield trim till I was going to have a cage put it. Summit poly seats with covers, S&W aluminum dash, all gauges are new except the tach, has two fuel gauges for if you want to run methanol injection and want to have a level put in so you make sure you don't run out, MSD 7al box, HVAC coil, and Mopar race wires. Aeromotive A2000 fuel pump and reg. , 20 gal fuel cell hasnt been mounted, is a square cut in the floor from the previous plastic cell that was in there.Haven't ran the engine in a long time. Summit brand wheel, have 15x4 front and 15x10 rears, if you don't want them will need to bring some rear wheels, have some steel ones for the front. Hoping to get $3500. Have stock header panel and front valance, new carpet kit and I a new weather stripping seal kit for the car, and new door handles. If interested let me know.
Can email a video of the first time we started it, can't seem to be able to upload, pm for video. Any other pictured needed, let me know too.
Have had this car since I was 16 my first Mopar
my engine-2.jpg 20140510_171807.jpg 20140510_171716.jpg 20200607_105351.jpg 20200607_105342.jpg 20130309_163339.jpg 50561-6f1469de2b7164ef6680965a4064227f.jpg 20200607_105600.jpg 20200607_105443.jpg
Also comes with some wideband for each bank, have two AEM uegos for it as well used but work, missing one Bosch wideband sensor, but have the wiring. The extra hole was going to be for boost for a later date. Have the headlight buckets for it.
