70chall440
- 5:12 AM
- Feb 11, 2018
- Yelm, Washington
So what are you guys running for your G3 Hemi fuel lines, meaning what size? I am debating on whether to use 1/2" or 3/8". Normally I would just default to the larger size and be done with it but 1/2" steel fuel is a little more difficult to find over 3/8" which is pretty plentiful. I am sure I can get it but I'd like to have options.
I want to use mild steel line, not SS or any form of braided for the long runs. I will use nylon braided for the soft lines (to the tank, to the regulator and to the fuel rails). I will be using AN fittings throughout.
I looked it up and it seems that 5.7 and maybe 6.4 use 3/8" line whereas the Hellcat uses 1/2". I see that there are adapter to go from soft line to the fuel rails so I think I am good there.
Let me know what you are running, perhaps even more importantly any issues you had or things to avoid.
Thanks in advance
Thanks in advance
