brad 66
got it going thanks for all the help
Did you forget the part about doing a few burnouts after getting it fixed?i ran a new field wire to regulator ,changed the regulator again , and a new wire from regulator to bulkhead connector.
Is there a reason why this diagram does not have the wiring for and include the voltage regulator? As I am looking at my charger and trying to troubleshoot why my battery isn't charging I see only 1 wire from alternator in this diagram. Should I assume the battery wire is the one missing and what is show is the field but without the regulator? Super novice so when I see phrases like "full field the alternator" I have to rely on pictures. Thanks.This is a simple diagram for your alternator output charging circuit. View attachment 943799
Because that is not a full wiring diagram. It is a diagram of making changes to one side of the amp gauge circuitIs there a reason why this diagram does not have the wiring for and include the voltage regulator? As I am looking at my charger and trying to troubleshoot why my battery isn't charging I see only 1 wire from alternator in this diagram. Should I assume the battery wire is the one missing and what is show is the field but without the regulator? Super novice so when I see phrases like "full field the alternator" I have to rely on pictures. Thanks.
Actually, the diagram I included was one without changes but ok, we'll assume you meant the next diagram. Good to know. So your response still left me with questions. Is the wire coming off the alternator in this non-full diagram the field wire?Because that is not a full wiring diagram. It is a diagram of making changes to one side of the amp gauge circuit
