1971 383 compression height
gtxrt
12:39 PM
central ny
doe's anyone know the piston compression height on a 1971 383 hp motor. thanks.
I took apart a standard bore 71 383 hp a few years ago. It was around 60 to 70 in the hole. With steel head gaskets and 906 heads, it came out around 8.2 to 1
that would make the pin compression height 1.87 doe's that sound right ?
got a hold of a stock 71 383 hp piston, came out to 1.865 compression height. .055-.065 in the hole on a stock motor comes out right.
OK, cool. The motor I put back together still ran strong, just needed a bit more stall speed since low compression makes a 383 a little soft on the bottom end.
