4mulas
- 12:36 PM
- Mar 16, 2017
- Just North of Great Falls
From the internet and a lot of research I have done previously..
Yep was just looking at those. Thanks.. Amazon has them for 34.00 Im going to order 2 just in case.
https://www.amazon.com/YCT-02580170...t=&hvlocphy=1015318&hvtargid=pla-906134738806
Bosch 17025 is what is recommended on the forums as a replacement. I very seriously doubt Holley manufacturers any o2 sensors. Even their website says it is a Bosch brand.I have to get one I see like numbered o2 sensors but not sure they are the same. So Im going to have to buck up and pay for the Holley version at 119.00 for a 40 dollar part lol.
I will just order one from here its a little bit more money but its the bosch. https://www.efisystempro.com/wbo2-sensor-sniper-tbi-554-155Considering the rest of your investment, if it were me I’d probably buy the brand name Bosch, who is YCT?
Ok I just went out and installed the card. Ran the wizard and started the car. Right off the bat the AFR was 35.6 with an IAC of 100% I assume the o2 is bad now.
If the new O2 sensor doesn't fix it I will do that.You could have a bad ECU. Call Holley and see what they say before spending any more money on replacement sensors.
https://forums.holley.com/showthread.php?21085-Oxygen-Sensor-Fails-way-too-early
Sounds like a lot of part swapping. Its pretty hard to kill an 02. They are designed to run for 100k+ miles without ever needing to be replaced.
Can you describe the chain of events that led to your question? Seems like the car was running then “something” happened and...? Were you messing with the timing or fuel tables? If so what were you trying to do? Shouldn’t need to replace parts in that situation. Maybe just re-run the Wizard and see if that clears things up. If not then you need to re-trace your steps and figure out what changed and go back to where you started.
I suggest joining the Holley Sniper forum since it exists for this very thing. Take a data log of the car running, upload it and see if you can get more help there.
My bet is that the things you think you need to replace are still OK and that whatever issues you are having are related to programming.
Not hard at all to kill an 02-sensor on a non-OEM application.
https://www.nzefi.com/bosch-lsu-wid...l-often-aftermarket-performance-applications/
I've killed MANY, enough where I essentially have a spare in the garage. Didn't notice a difference from NGK, Bosch, or any of the various manufactures I've tested. I'm running one now off Amazon, for $35 it had an identical reading as the NGK. 200-miles on it so far.
Should have the new 02 sensor in the next day or so. Hopefully that is the issue and not the ECU. Replacing the 02 on my friends GTX worked. So maybe that's all it is. If not I will be shipping the sniper back to them. I Do not believe the sniper is at fault but who the hell knows.
What # do they want, 20% is about right for most systemsInstalled the new Bosch O2 sensor and fired it up and its running great again. AFR is at 13.5% Im a little worried though I was looking at the IAC and its saying 20% I tried adjusting it as the video says but that's the lowest number I could get out of it. But I also just started a brand new tune so that may have something to do with it.
I get all thatActually that number is between 1-5% and best with 1 or 2 but it can be tricky to get it to stay there consistently. Think of it like the transfer slot on a carburetor. Ideally you only want a little bit of the slot showing, .020" is the number I've always used. Not all combos will be able to achieve proper idle with it like that but .020" is generally where you start.
To the OP, are you using the software on a laptop or doing everything through the handheld? The handheld is pretty limited, the software will help illuminate things better.
To me EFI is way less efficient without the software because you're just guessing at what the tune is. You could be leaving power and/or economy on the table.
The target AFR table is the heart of everything so your 13 reading could be whatever you want it to be for a given rpm and/or load. That is unless something like an intake or exhaust leak or other problem prevents the ECU from correlating it.
Some may be OK without the software that but for me things changed pretty dramatically when I figured out how to build a custom tune.
When you watch the video on how to set the IAC it says to get it as low as possible. In the 5% range. But im stuck solid at 20% Was at 56% then turned the idle screw down. And reset the computer so the TPS would 0 back out. Did this several times and I can't get lower than 20. Crap... After re-watching the video I missed a step. I did not disable the idle spark. Guess I'm going back out there before I end up pulling the intake.I get all thatmy Charger, street car, most EFI want the IAC in the 20% range, to the OP, what does the manufacture of YOUR EFI want for the IAC at idle ????
