Project update; Control Freaks/Strange 60 4-link Installation
Mheiron
9:12 PM
Houston Texas
I got the Rear big stuff installed and thought I’d share a few pics.
Got my driveshaft measurement and placed that order with Drive Shaft shop. Ordered the driveshaft loop from USCT.
Next comes final welding and then paint. I need to setup the welder to put argon inside the frame rail for final welding as there is no access for cleanup behind these welds.
04E9F003-38A6-49ED-B332-37C945AB5E2F.jpeg 415D1640-67E5-4A1F-8FC8-36F5AC3CDA2E.jpeg EFE9BC73-A4E9-4CC5-BAED-BACC5F853679.jpeg 8426D208-38A7-453F-8062-8E8D30C84AD5.jpeg 246D3EC3-FCAA-45F2-940C-8187A72DE088.jpeg D372027A-DFE9-4732-87D9-E00EF4CBC371.jpeg
Everything is tack welded now. Yes I use MIG with .035 wire
I'll be rigged up to fill the frame rails and diff with Argon mix while final welding.
Do you prefer TIG?
Do you prefer TIG?
I use what I have (stick and MIG) TIG is great but, I haven't purchased a rig-yet. I may never. I just never ran across purging with MIG welding. We did hundreds of TIG welds (food grade stainless) with purge gas when I was working. I suppose it would work equally well with MIG welding but, how will you be finishing the inside of the frame rail?
Ill finish the inside with Eastwood internal frame coating.
I use their kits in all my stuff. Great kits, will ride fantastic. You should really enjoy the car when you are done
