rumblefish360
Sounds like it’s time for an electric fuel pump to get that fuel delivered quick and easy. Your starter will love you for it.
Hmm................ Well I was going by the Edelbrock manual with the 1/8" gap, but I will have to try the "full closed" next year as mine takes longer to start than I think it should as well.I believe it needs to be fully closed but soon as the car fires off, the choke pull-off will crack the plate about an 1/8 of an inch.
there is an adjustment rod to set the gap with.
if you live in a very warm climate - the cold choke set like in the picture will likely work ok.
Sometimes if choke tension is not enuff the pull off starts to do its thing and the plate opens too far.Not enuff tension lets the choke plate open too far just from air rushing down venturi's.Hmm................ Well I was going by the Edelbrock manual with the 1/8" gap, but I will have to try the "full closed" next year as mine takes longer to start than I think it should as well.
No. It is proper adjustment for it to close until the engine starts. Why have a choke if it doesn't close. One set too lean (open even slightly when closed) makes it hard to start.Maybe I'm wrong, but it just seems to me that a fully closed choke would literally choke off the intake and prevent the engine from starting.
You really need to know if the choke is closing all the way when the engine is cold. If is sits for a few days then fill the center carb through the bowl vent.
Don’t pump while cranking, it will open the choke. Also will help it to go lean and backfire through the carb destroying the power valve,
OK, I'm gonna have to readjust and try it again in spring, but we all know that an IC engine needs 3 things, fuel, spark and air. Again, I may be wrong, but it seems to me that with the choke completely closed, you are eliminating one of those three things. What am I misunderstanding?No. It is proper adjustment for it to close until the engine starts. Why have a choke if it doesn't close. One set too lean (open even slightly when closed) makes it hard to start.
Yes. . It get's air but it needs a rich mixture to start. As soon as the engine fires the butterfly will open just a crack to prevent flooding. The butterfly, like they mention in the videos, is set to "just close".OK, I'm gonna have to readjust and try it again in spring, but we all know that an IC engine needs 3 things, fuel, spark and air. Again, I may be wrong, but it seems to me that with the choke completely closed, you are eliminating one of those three things. What am I misunderstanding?
I can tell you one thing for sure, with my completely stock 440 if the choke is opened at all (cold), even a small amount, there's no telling when it will start. Fully closed it will start in a matter of seconds.Maybe I'm wrong, but it just seems to me that a fully closed choke would literally choke off the intake and prevent the engine from starting.
