19 69 GTX
- 2:56 PM
- Apr 30, 2016
Ok anyone want to guess the hp and torque of my freshly built low deck 512 stroker. Bottom end is 440 source 512 stroker kit. Cam is the Trick Flow roller cam which specs out at .600 lift and 243 intake and 247 exhaust @.50. Trick Flow 240 heads with Harland Sharp roller rockers. Trick Flow intake top with a Quick Fuel 950 cfm. Compression right around 10.3 to 1. Really a fairly mild build but wanted a really streetable combo for my 69 GTX that will have a new Tremec 5 speed and a hydraulic clutch. Out back will be the factory Dana 60 with 4.10 gears. I may switch back to the 3.54 gears. Dyno will happen hopefully sometime next week. My guess is 605 hp and 670 tq.
