19 69 GTX
- 5:00 PM
- Apr 30, 2016
Those things look nice, but are junk. I tried one last fall. 2 issues with them. Like you stated, the newer style cables with the plastic around wire will not fit in the clamp. I took a die grinder with a 1/8" wheel and widened the slot. That worked fine. But after doing that, I found a bigger problem. The throttle shaft linkage on your carb moves in an arc. The cable clamp is positioned to high, preventing any chance of WOT. Talked to Allstar about the design flaw, they didn't seem to care. Luckily I bought mine from Summit. After explaining everything to them with pics, they agreed and gave me my money back even with the mod I did.
I'm using these brackets on all 3 of my cars. I modify them a bit to get a nice angle for the arc of the throttle shaft.
Yes it is.Looks like the one I got from Mancini. For tall intakes and its adjustable
What bracket are you using? I'll be needing to set one up on my coronet this spring.I'm using these brackets on all 3 of my cars. I modify them a bit to get a nice angle for the arc of the throttle shaft.
These work well.What bracket are you using? I'll be needing to set one up on my coronet this spring.
Thanks, looks like just what I need.These work well.
https://www.manciniracing.com/man383en.html
This is Mancini's 440 bracket. Worked very well on my single 4 bbl Hemi.Also their kickdown cable kit.
