Sonny
20-50That is lower than I like,what weight oil do you use?
The rest look fine.Personally, I’m not of fan of the “chemistry set” mix-n-match oil combo.
I also don’t like to use modern low zinc oils in these classic engine platforms.
As has been mentioned...... use oil formulated for the job at hand.
But, that may or may not have had any part in the failure.
Be interesting to see if you have other lifters that have visible wear on the bottoms.
If it’s only the one lobe/lifter, I’d say it’s less likely an oil issue.
Multiple lifters going away?
I’d be suspicious of the oil.
They still have that curve on the bottom?The rest look fine.
Agree that's kind of low for 20/50w. Think I have a high volume pump and sure I have full groove mains. Avg. clearance M/R .0023, C 75psl w 40psi with Shell 20/50w diesel oil. Engine needs to be disassembled, cleaned and clearances checked if there's nothing obvious wrong. Gallery plug loose in cam area, doubt it.10lbs at idle with 20-50 oil.
I was using a high volume pump…It has low idle pressure because the pump speed isn't great enough to provide enough flow to overcome the internal leakage. A high volume pump will help. As will reducing internal leakage. Loose lifter bores, large main and/or rod clearances are usually the major culprits. But there's nothing the matter with large bearing clearance. Or low idle oil pressure either for that matter. 10 psi per 1000 rpm will be fine.
Comp cams.Very sorry to see the damage Sonny. Did you ever state where the lifters were sourced? Maybe a flat one from the factory, or maybe it just wasn't spinning.
When I built my motor I checked every one for a dome and matched them to bores and checked for rotation.
The history is what makes it work. You can change oil at whatever you feel good with.
