Braces for 67 4 speed
440 4 speed
11:43 PM
Saskatoon Saskatchewan Canada
I didn’t take enough pictures of the rod placements. I appreciate it if some one could send me detailed pictures of where they go, or tell me where to look for information I would really appreciate it. I have looked a pictures on e bay
but not the same as mine.
F037802E-0D6B-42F4-82C3-FA9C9E869F38.jpeg C3D0D6F6-A500-4303-86DA-DC5BAE5A7FC3.jpeg 3F5F810B-1B6F-434E-9910-2493AB1391B6.jpeg
These are from my 69 charger. As far as I know the braces are the same manual or automatic.
Thanks, the dog leg one to the steering column should work. In my second picture I don’t have the same bracket to bolt my rods on. Looks like mine have to bolt from the bottom. Then to where?
I appreciate you doing this.
Are you sure you have the right brackets?
Here are some of my 69 Bee. Same as pnora posted above. I thought 67's had the same mounting setup as 69's?
The picture with the trouble light shows my bracket.
Definitely different than 68 and 69. Maybe try sending Jerry Hall a pm. He has several 66 and 67's.
View attachment 1252120 View attachment 1252122 View attachment 1252123
I remember taking one brace off the drivers side kick panel to the steering bracket on my 67 coronet.
I did not take any pictures.... Jerry Hall may shed some light on the subject.
Post them if you get some please.
My 69 Road Runner that I just restored had that long brace as well. It is the only car I have owned with that brace.
Yes it was a long brace going just above the left kick panel to the steering column bracket.
my car is a 4spd car.
Thank you! If you look at my photo’s, my bracket does not have the L shaped bracket that your two rods bolt to on the vertical. Looks like I have to bolt mine from the bottom hole.
Will go out and turn the heat up in the garage, -29C right now.
I think Mopar Action might have had an exploded view of the whole assembly, but can’t possibly remember what issue.
Haven’t contacted Jerry yet.
3ADC48C8-6A95-409A-8CDC-01B61196D92A.jpeg EC8A370B-F244-4ED5-A5E8-F4EA9E947DFB.jpeg
