GreatCuda
I recently bought a set of new Edelbrock heads for my '74 440 Cuda and I've had some adventures getting the stock exhaust manifold studs and sleeve nuts out of the stock exhaust manifolds.
The rear most sleeve nut on the driver's side exhaust manifold has caused me to have to remove the driver's side motor mount bolt and jack the engine up to get the sleeve nut head away from the steering column far enough to get a wrench on it.
I have to remove both exhaust manifolds completely to get to the lower/outer head bolts on both heads.
I notice that Edelbrock says in their installation instructions that the heads need to be re-torqued after initial startup and cool down.
This is going to entail getting those bi*tch kitty manifolds back out again to do that.
Does anyone know of a work around to avoid having to do that all over again?
