fmahannah
1963 Dodge Polara Max Wedge Tribute
- 2:52 PM
- Sep 25, 2014
- Dahlonega, North Georgia
Rebuilt my two Carter 3705s on max wedge intake using kits #4051A from quadrajet parts. Noticed the base gaskets were different in the kit from what were on them when taken off the manifolds. It looked like there were vacuum passages on base plate where on old gaskets they were not covered but on new ones they are covered. I am attaching a pic of what the new gasket looks like (the one on the far left). Also noticed differences in the venturi gaskets where old ones were cut between some passages and new ones were not.
The reason I am asking is I had issues with the carbs after rebuilding and have had to remove them several times, and each time the area of the base gasket that is covering the passages on the base plates has swelled upwards towards the carb more to the point where the last time I put them back on in the same positions the carb actually rocks back and forth on the gasket?
I can post pics of the swelling I am talking about later but does anyone have a pic of what the correct base gasket would look like for 64 max wedge carter 3705 carbs or where I can buy them?
Forrest
Forrest
