FOUND 1964 FURY LEFT SPINDLE
Red63440
5:46 PM
NY
Feedback: 3 / 0 / 0
I ran into an issue when I was installing my disk brake conversion, my left spindle is bent. It wasn’t a problem with the drum brakes because the shoes could move slightly due to the springs. The spindle is actually bent downward which is causing the caliper to drag on the rotor, passenger side is perfect with no issues.
All I need is the spindle, no backing plate or drum.
I have one for 64 polara 383 but is drum.
Does it work for you?
I have both off my 66.
They still have the control arms attached but I believe they are the same.
Let me know if you want one.
Don, if they are the same that would be great! Just need the left side please.
Okay we are doing some work in Batavia.
Let me look into getting it there.
