Michael400
Hi I'm Michael I'm new here and I'm currently working on a 73 Dodge Charger done some modifications took it to the dyno just want to see if these are good numbers what do you think it'll run on the quarter mile or 1/8 of a mile
400 big block 30 over
7194 Edelbrock cam Camshaft Specifications: - Duration @ .050 Intake: 238 degrees - Duration @ .050 Exhaust: 246 degrees - Lift @ Valve Intake: .480" - Lift @ Valve Exhaust: .495" - Lobe Separation: 110 Degrees - Intake Centerline: 105 Degrees
750 Edelbrock Performer Series Carburetor 1411
Edelbrock RPM intake manifold 7186
TTI headers 1-3/4
Two and a half inch exhaust with MagnaFlow mufflers
High top pistons don't know the actual compression last time I checked the crank pressure they were at 145 to 155
323 rear end gears
Accel ignition coil
NGK XR5 spark plugs
Stock cylinder head [346 not ported]
Timeing at 35
Firecore spark plugs wires
Mopar distributor stock version
Torque converter TCI stall 2400 - 2600
180 thermostat
Power steering AC installed but not working
Stock crank stock fan clutch stock 727 with a shifter Improvement kit
It made 286 hp and 330 tq
Rear tire 275 60 r15
TTI headers 1-3/4
323 rear end gears
Accel ignition coil
NGK XR5 spark plugs
Timeing at 35
180 thermostat
