- 10:38 AM
- Feb 22, 2021
- Roswell, New Mexico
Let's go back in time. The year 1977.
The example vehicle is a Jeep CJ7
equipped with a carburated 304 V-8.
Engine tolerances have not yet transitioned
to the tight ones experienced today.
Let's say the Jeeps' cat has been removed,
the engine is bored, heads decked, 4 bbl
intake installed along with some headers
a lumpy cam, and a high stall.
What makes this powerplant any different
from a 1968 monster 440 other than make
and legend? The internal tolerances would
be compatible, yet, one requires the use of
ZDDP, and the Jeep has been run without
this recommended additive for a number
of years, with zero internal engine failures
other than normal wear and tear.
If the lack of ZDDP is wiping out cams,
would not the Jeeps' cam suffer the same
fate.? Bear in mind that this was before
ZDDP was found to be detrimental to
cats.
Could pushing the limits on engine builds
truly be the cause of wiped out cams? ie...
increased spring pressures, etc.?
cats.
