Light between the speedometer and tachometer
Myasylum
12:41 AM
What is the light between the Speedometer and tachometer? It's a small round light. Looks like maybe a red lens should be in there? It's missing, and it's bright and doesn't turn off.
This light here. The one that it lit up.
Brake light? Fasten Seat belt light??
I am pretty sure that is a brake light. Check the emergency brake or look to see if the proportioning valve switch is stuck.
brake warning light
HI ,
that light does two things.. It tells you if your brake porportion valve is bad/ brake problems and it also tell you when your park brake is on.. sometimes the park brake doesn't quite turn all the way off. check it at the switch at the park brake pedal.. touching it is fine if it is not touching it the light well be on.. It kind of works backwards.. pushing the button in the switch brakes the connection and the light shouldn't be on.. if its not toughing it .. it makes connection and turns the light on..
good luck take care be safe
tim
Not stuck, but with some pressure diff between rear and front brakes system ( such as a leak ) which will move a double action piston to activate the switch on brakes dist block.
