440 will not run Please Help
0DegreeEngineer
3:49 PM
Fountain
Hello if I could get some advice that would be great I am currently attempting to get my 440 up and running in my 69 GTX and cannot set timing, when I get the engine running good and go and tighten down the distributor the engine misfires and stalls out, this is the second distributor I have installed on this 440 in the past 12 months, am I possibly over tightening the distributor? or is there something maybe on the shaft that could be causing premature wear? any help or ideas would be greatly appreciated.
Mine the vacuum advance canister was loose. As soon as id go to tighten bolt I’d bump the advance can and it would die. Took me a minute to figure out what was going on. Worth a look.
It runs fine until you tighten the distributor clamp? How bout if you just snug it down?
Take the distributor cap off and see what moves as you tighten it. Something is changing, look closely.
I will check that out and post back
only likes to run it seems when it is loose any pressure on the hold down and it starts stumbling
Make sure the distributor doesn't rotate when you tighten it down. Mark it when it's running good then shut it down and tighten it then check the marks.
Sometimes when you tighten bolt that last turn it moves the distributor a bit. Is it doing it enough to cause your problem, maybe not...but to rule it out I might put an index mark on the base of the housing and the block to see if there's any movement happening when it gets tightened all the way.
Looks like Cranky tree'd me! You still got it old timer!:D:D:Dhahaha
What distributor is this? Points or electronic? A points distributor needs to be grounded so that could be something to check on. Do you have a stock hold down clamp, or some custom chrome thong?
did not see a rotation bot I can definitely tell the distributor "rises" when tightened
Points distributor with factory hold down will post pictures tomorrow.
Is it possible that the bushing under the distributor drive gear has excessive run-out or axial movement?
BOB RENTON
Has your engine had any recent engine work done? Rebuild, can change, oil pump or oil pump drive?
My 2 cents worth would be to first determine why the distributor is "lifting" when the hold down clamp is loosened. I would start by checking the base of the distributor and where is sits in the block and then measuring the shaft length and the gear positioning. I have seen distributors turn slightly when tightening them but never enough to stall the engine. If I had a spare distributor, I would put in to see if it also lifts. If it does I would then check the drive for the oil pump.
Good Luck!
Maybe add a couple steel distributor base gaskets to space it up? (not an o-ring)
The 440 & SB dist are close in length. Not sure which, but one is slightly longer.
Could it be the wrong dist?
