Well thank you, I have 1 coming but I really don't know if it's gonna work till I lay eyes on it. It is a complete assembly also but with cable control temp. Mine is vacum. I might be reaching out to you.Hi Roger I have the whole assembly if you can’t find just the switch.. I really don’t want to part out the unit..
Just thinking about this.. I believe you will also have to change the water valve under the hood and some parts on the heater box too to go from vacuum to cable.. might be opening up a can of worms..Well thank you, I have 1 coming but I really don't know if it's gonna work till I lay eyes on it. It is a complete assembly also but with cable control temp. Mine is vacum. I might be reaching out to you.
I think I agree with you, what I hope happens is that I can put the vacum heat control on the controls that I purchased. It's a wait and see moment. Does yours have the vacum heat control?Just thinking about this.. I believe you will also have to change the water valve under the hood and some parts on the heater box too to go from vacuum to cable.. might be opening up a can of worms..
Yes mine is the complete unitI think I agree with you, what I hope happens is that I can put the vacum heat control on the controls that I purchased. It's a wait and see moment. Does yours have the vacum heat control?
