Also check or block off the brake booster.Yeah, wouldn't hurt to push the timing up some more just as a check but if it likes it and you're getting some ping up top, you might have to recurve the distributor to pull back some total.
And do you have yet another known good carb to stick on and see if it still has the bog? If so, I'd start looking at an intake leak especially if you advance the timing and it doesn't do much....and it wouldn't hurt to block the PCV as a test.
