FOR SALE 68/69 Satellite/RR/GTX parting out
I'll be in touch around the 23rd. If for whatever reason you don't hear from me feel free to reach out - thanks.
Looking for side markers for a 69 GTX a dome light and a under hood engine harness thank you
Hey there, I’m looking for a few nuts and bolts. I need:
1 lower ball joint castle nut-the main one that attaches the ball joint to the lower control arm
1 strut rod nut-need the small one that faces the front of the car
6 leaf spring hanger nuts-these are the small nuts that attach the front leaf spring mount to the body
3 of the screws that mount the steering column to the firewall, they screw in from under the dash
Let me know what you’ve got.
Thanks,
Erik
I need the upper and lower cowl section with the steering column and dash frame screw brackets still attached. Any way you would be willing to cut one off of those car's and ship it to Michigan? The repop's don't come with the brackets so if I can get a section in good condition I'd rather use that any way.
How much for the gauge cluster?
I can do that, but I want to make sure I know exactly what you need. Can you send a picture or, ..?? A link to a catalog or pic of the repop advertisement would be great.
Thanks,
Erik
I believe I can help you with all of it. Let me know if anything needs to be added to your list, if you're still interested.
Yup still interested. If you have them I also need basically every internal component of a passenger door minus the lock, exterior door handle, and main regulator. I need all the window tracks/rollers, the inside door handle, and the rod that connects it to the locking mechanism. Let me know what you’ve got, take your time. Thanks
Good morning Erik. The door I have has already been gutted. The only items there are the vent window frame and outside door handle.
