WTB Manual brake master cylinder pushrod.
KnuckleDuster
8:45 AM
texas
Feedback: +0 / =0 / -0
Doing a swap on a 64 Polara, from single reservoir master cylinder power drum/drum brakes, to dual reservoir manual disc/drums. I need the correct or adjustable pushrod.
The stop light switch may need to be modified with an adjustable push rod. There's a tip on stock push rod. Had the problem on my 65 Dodge Coronet.
Would a push rod from a manual drum front and rear with a single reservoir work?
If so I have one from a 64 Plymouth
Dr. Diff normally has them but seem to be currently out of stock. Could call and see about ETA.
Yeah, I probably need to contact Cass, and at least nail down what I need. I swapped to manual on my Duster years ago, but my memory is foggy. This is my first early B body, and I've had it six days, so not sure what interchanges, yet.
I have one from a 1968 B Body manual brakes 4 wheel drums if you don't find one from Dr. Diff.
As far as I know, this is the one I need.
Thanks for all the replies. For some reason I am not able to PM after the update.
I just found out when I tried to pm a member about a set of locks/keys.
Got sidetracked with some other stuff. Still need the factory 62-65 pushrod with the associated parts, as well as the manual firewall plate.
I still have the one I posted pictures of.
I will sell it to you.
PM me for info
Ed
Did you modify the adjustable pushrod or the stoplight switch to make the adjustable rod work?
A stock manual rod 62-65 should work. Ed says that he has one and a I have few too. 66-70 is different.
Is this the bare pushrod after removing the plunger from the single reservoir pushrod as in the second picture - or is this different pusrod?
The adjustable pushrod doesn't have that small nub on the end. That nub hit brake light switch. I move the switch, might be easier to tack weld a piece. I didn't have a welder at the time.
Thanks. I have a new adjustable pushrod without the nub on the end for the switch and I have an original style single master cylinder. I tried removing the pushrod from the single master cylinder - it would not come out - but I guess I didn’t pull hard enough. It would still have that plunger on the end and I don’t know if that comes off.
