Control arm bushing tool
joe smith
1:33 PM
Florida
Can anyone recommend a bushing remove/install tool ??
Or should I just have them done somewhere?
Mancini sells a decent front suspension tool kit if you are looking to buy.
Its an 83 mustang, lower control arm. My ball joint removal tool will not work on the bushings. When I check online with AZ or O'Reillys about their rentals, its non compatible with my car..
Have you tried a socket large enough to fit over the bushing and a piece of all thread rod with washers? Draw the bushing into the socket. Grease up the rod threads.
Same concept as the "kit" attached but alot cheaper... I will give this a try
Thank you
