- 2:32 AM
- Jul 1, 2015
Accuracy depends on calculations. Supposition depends on NOTHING. Best thing to do is engage brain b4 writing.....Well I have been able to feel some dragging when alt is providing power on a "high" load stage. 1HP per 50 amps? Hell I don't know. I think could be a bit more, but can't say it certainly. Instead of meaningless guessing, do the calculations and KNOW the results. Its not strictly amps to HP calcs, but includes rotational (frictional + windage) losses. Since there is USUALLY a common drive method (fan/water pump + alternator) each driven device losses must be factored separately and the redults added to determine total losses and includes belt losses
Net vs Gross power makes a big difference, sure not because just the alt, but adding water pump and... steering pump too? Dunno if we talk about cars without power steering. You're referring to just alternator losses. The other items mentioned, use different loss calculations. Pump losses vary as the square difference between RPMs from first poiht to last point of RPM scale used for evaluation.
BOB RENTON
