Anybody on here admit to pulling the threads for the steering box mounts? You know, the welded on nuts, one being inaccessible. And if so, what is the best way to repair? Got only myself to blame for this one.....
I can understand.....but the only easy fix I can think of is to drill it for an insert. If the engine is in the car, that will make things hard to do if that's even possible.By the way, this is in my freshly restored 69 Bee. Firm feel kit welded on, seams welded, blasted, and painted. I'm just sick to my stomach at the moment.
If it's the outer one, might be able to fix it with the engine in place but can't see doing it with the steering box being in place. Heck, the box probably should come out for any of them....The outer one?
Agreed.....drill out and use a Heli-coil insert.I can understand.....but the only easy fix I can think of is to drill it for an insert.
Oh yeah, in the car and done. Was done anyway.Dayam!! Is the engine still in the car?? Tap to the next biggest size????
The outer one as well as the top inner. The inner one I could add a nut to the front if I had to, but the outer hole is not accessible.The outer one?
I'll have to get the K-frame out of the car to do that, which with my luck will have to happen. The other thing is that a 1/2" helicoil needs a 17/32" drill bit. I don't have one, but am sure can buy 1 somewhere. Then I am looking at the size of the coil. Once the nuts are drilled out for that, there sure wouldn't be much metal left on the original nuts. Not even sure how strong that would be.Agreed.....drill out and use a Heli-coil insert.![]()
When I had originally put the car together, the treads were fine. I had an original box that was rebuilt several years earlier and run in another car. After driving that for a bit, I decided to remove it and send it to Steer and Gear. for a refresh. Then this spring, PST came out with their new 20:1 boxes. Bought one of them and installed it a couple weeks ago. I really like it, but the steering wheel wasn't perfectly straight. I drove it probably 40 miles or so. Had an appointment for an alignment this morning to get the wheel straight and check everything else. Drove it into town and remember thinking that the steering does feel kind of sloppy and I'm glad the alignment is getting done. My 64 year old alignment guy drives it on the rack and immediately asks what I did to it while moving the wheel back and forth. We pop the hood and had a look. Here the shaft on the new PST box was moving 1/2 turn before the tires would move. While turning, the shaft was also coming out of the box at least a 1/4". So he sends me home of course, and I'm lucky I made it. 2.5 miles and hardly and steering, getting worse every time I turned it. Didn't go over 20 mph the whole way. So I have changed the box at least 3 times, but the big mistake I made was slobering up the bolts with anti seize and trying to get the 100 ft. lbs. of torque stated in the FSM. When I put in the PST box, I knew I had a problem and didn't sleep well for 2 nights because of it, wondering how I was going to fix it.dang elk! That sucks but I gotta ask how did the threads get damaged?
The helicoil will work. The 1/2 -13 helicoil insert is 3/4 of an inch long. So that should have plenty of strength.I'll have to get the K-frame out of the car to do that, which with my luck will have to happen. The other thing is that a 1/2" helicoil needs a 17/64" drill bit. I don't have one, but am sure can buy 1 somewhere. Then I am looking at the size of the coil. Once the nuts are drilled out for that, there sure wouldn't be much metal left on the original nuts. Not even sure how strong that would be.
I was thinking more of the width of the original square nuts as far as strength goes. I had to leave the garage for the night to clear my head, but will measure them tomorrow. I'm thinking they are only 3/4" or so across, and then drill a 17/32" hole. That doesn't leave much.The helicoil will work. The 1/2 -13 helicoil insert is 3/4 of an inch long. So that should have plenty of strength.
