Can someone give me the part number for a big block stant 180 degree superstat?
Just a brand name I know and have used the most but probably as equal choices out there as well.I don't know but i just bought an Edelbrock 180 degree thermostat for mine, i think it's this one:
Edelbrock 8607 Edelbrock High Performance Thermostats | Summit Racing
Free Shipping - Edelbrock High Performance Thermostats with qualifying orders of $109. Shop Thermostats, Mechanical at Summit Racing.www.summitracing.com
Why stant?
although I think our engines came with a 190??
that’s why i’m looking for a superstat they are not standard flowJust keep in mind the edelbrock has more flow. You might want or not want that.
All i can say is the original mopar thermostat looks more like the edelbrock unit than the gates replacement i also bought.
Should be this number 45358.that’s why i’m looking for a superstat they are not standard flow
I have a couple of brand new ones I would let go if you can't find any.Can someone give me the part number for a big block stant 180 degree superstat?
What is the difference on your 45478 and the number I posted 45358 ?
MotoRad/Stant 45478 Stant SuperStat Thermostats | Summit RacingWhat is the difference on your 45478 and the number I posted 45358 ?
That 45478 looks exactly like the one I have I guess it could be a superstat. In looking at the descriptions between 45478 and 45358 is the latter states it has a V notch to allow air to escape. Does the ones you posted have that notch?
I'll check in the morning. Do you know where the notch would be? I always used to drill a 1/8" hole in them to help bleed.That 45478 looks exactly like the one I have I guess it could be a superstat. In looking at the descriptions between 45478 and 45358 is the latter states it has a V notch to allow air to escape. Does the ones you posted have that notch?
I’m not sure that’s the first time I read that but I do think the one I have is a superstat 45478 but not 100% sure.I'll check in the morning. Do you know where the notch would be? I always used to drill a 1/8" hole in them to help bleed.
