 - 6:33 AM
 - Oct 16, 2014
 - Salisbury, Vermont
Working on taillights. The ignition module came with the fuel line.
			It's chinesium, it's what I could afford right now.May I ask what brand ignition module that is?
I had a Mallory unilite on my car, and the original module went out, I bought the cheaper non accel and msd one. It made my car run like garbage. Could have been the vacuum advance or something else, but I gave up on it and went a different direction. I just thought I’d warn you
Could have been other issues with my distributor, or could have been that. It did run good for a while, I wish you luck!It's chinesium, it's what I could afford right now.
I'm having a hard time deciding to go black with mine or red like the factory did.. black is just sooo much easierIn the mean time i'm sanding down the trim to paint it all black.
What about wet sanding out the runs and what not before shooting more paint?You can wet sand it but it will show every spot that you sand if you try to clear over it. That is the problem with single stage metallic paint. It will look like crap if you do that.
