Speedometer jumping around after hitting the brakes
Michael_
11:54 PM
Germany
My speedometer functions normally most of the time.
But when i hit the brakes the needle is going up and down for a while until going back to normal.
I already found this thread with lots of good suggestions
But i was wondering if you guys already know exactly what this is given the behavior described above?
[/URL]
Make sure that your brake pedal 'arm' is not interfering with the speedometer cable under the dash - the pedal may be pushing the cable housing around when you apply the brakes.
This is assuming you have a cable driven speedometer.
If you have an electronic speedometer with a Hall effect drive - then you need to run a screened cable from the speedometer sender unit to the actual speedometer gauge.
That is a great idea.
Yes it's the original cable driven speedometer.
I checked and this isn't the case.
The cable also seems to be correctly seated in the speedometer.
I will check the transmission side next but it almost looks like it's the speedometer itself unfortunately.
