R134A issues and alternatives
70chall440
9:15 AM
Yelm, Washington
I have only recently discovered that the Gov of this state (Washington) signed into law a bill that bans the sale of R134A (actually happened last year). Like many, I own a lot of AC equipped cars but most notably the 71 Charger I am building will have AC.
I am now pondering how to charge this car and perhaps how to recharge some of the others as it becomes necessary. I see that there are alternatives such as R1234YF which I "believe" is still available here.
Looking for any information or perhaps just a discussion on the subject.
I still have a jug of R12 and only 1 ride to use it on, a 92 1st gen Dodge 250. I need to find a cycling switch with the capilary tube but have it jury rigged for now.
R-22 is way worse, now manufacture is banned countrywide. The wholesalers stockpiled it for a very long time. Why should you be any different?? One hobbyist is NOT going to destroy the planet. I saw a website saying even in Washington, the stores have failed to pull it from the shelves. Go get some, lol.
R134A Buy as much as you can.While you can.
I use stuff called envirosafe r134 replacement and freeze 12. It's a touch colder than pure r134a. It has some flammables in it but I don't care about that. I can snap a pic of the can, got it off of ebay.
Hundreds of thousands of high tonnage chillers out there running 134a. I’m talking about chillers, centrifugal and screw machines, running between 250 and 1500 lbs of 134a. 42-44* chilled water.
1234yf is about 40 bucks an oz and is not able to be retrofitted to r134 or r12 systems. I doubt we will see anything to replace 134 for a bit.
That was my next question, is there anything (not banned) that I can use in vehicles that already have R134A?
I use stuff called envirotech freeze 12. It's a touch colder than pure r134a. It has some flammables in it but I don't care about that. I can snap a pic of the can, got it off of ebay.
I am interested to check it out
I just looked that up and it appears to be a spray can that you use to clean keyboards and the like.....
I will go out to the garage in a few minutes and snap a pic, then you can search ebay. I buy it by the case.
Move out of the state. Your politicians are idiots.
Wait, forget it. That’s true everywhere.
I wish I could (and yes they are idiots) but I am too far in, I have two 40x60 shops full of Mopars not to mention a lot of other crap, plus I am close to Ft Lewis (aka JBLM) where I retired and still have teammates and friends along with the services on base.
The bottom pick is what I ordered a case of. I don't believe they still make the top one, but it's the same stuff. I couldn't find a fitting to screw onto that small oil charge can, so that's why I still have it. Hope this helps.
Thats helpful, thanks. I just looked it up and a case of 8oz enviro-safe is like $100
