Mark1972
Got the new CompCams 1621-16 set in. Shafts with oil holes down. Proper .030" clearance between rockers(had to do some sanding), and hold down bolts torqued to factory spec 25ft/lbs. All left and right rockers in proper place. Valve clearance set, and preload done(at base circle). Then installed new filter(WIX51515) and put 5 quarts of Driven 10/40 hotrod oil in. Put as much as I could in the filter without it pouring out. Cranked the engine over with a bar on the crank a few turns, but no oil coming out the rockers(valve covers off). I used Driven assembly lube on everything, and poured the engine oil on the rockers shaft/arm assemblies. Took the coil wire off and turned the engine over for about 3-4 seconds. Still no oil. Ok, wtf? No leaks underneath.
P.s. usually, the oil pressure light(don't have a gauge yet)turns off as soon as the car turns over for 1-2 seconds. After 3-4 seconds, it's still on.
