FOUND drivers side quarter window upper slide bar.
Brandy
Jack Stand Racer #6..and proud of it!
6:22 PM
Salisbury, Vermont
Feedback: 20 / 0 / 0
Not the one with the curve in it, the other one that's flat, about 7-8 inches long and has a stud on each end to poke through the sheetmetal and take a threaded nut. The opposite end of the crank scissor rides back and forth in it horizontally. I have managed to lose that one. Thanks.
The blue arrow points to it.
I got one for you, needs a bead blasting or soaking in evapo rust but it’s solid and the studs are good
You can have it just reimburse me for shipping, if you don’t have access to a bead blaster I’ll take it to work tomorrow and clean it up.
I don't, thanks! Randy Bisbee, 2108 Old Jerusalem Road, Salisbury VT, 05769 It ought to fit in a Small Flat Rate box. I think they are like 7 or 8 bucks. How do you want to be paid?
I don't suppose you have a couple of 3/4" rubber body drain hole plugs?
How are you measuring the 3/4 inch size? I only found one that was 3/4 measured with a vernier caliper in the groove where the sheet metal will be. I have plenty that measure 5/8 and plenty that are 1 inch
just across the lip of the hole. I some 1 inch that wont fit. I mean, i can always widen the hole to use another size.
Are these the right ones or should I hold off?
