1969 hemi super bee engine harness
Beekeeper
It’s a disease without a cure!
11:45 AM
Rogersville,TN.
could someone post up a good pic of a 69 hemi wiring harness focusing on the ballast resistor and voltage regulator wires.
thanks
This is a 67 GTX, but the area you are talking about should be the same.
The reason for the need of pics is because I purchased a new engine harness and the voltage regulator and ballast resistor wires are too short. Both parts are in the factory location the best I can telll and the wire looms on the firewall are what it was born with.
Here’s a few more to look at the coil wires are short as well.
Who's harness?
I’ll start by saying I’m fairly certain that all the components on the car are in the correct location. I started the install of the harness and connected it to the bulkhead plug and started across and came the the 2” or more short voltage regulator wires then then the short ballast resistor wires. So I called and sent pics to the guy who made it
and the reply was ”looks short but hard to tell in the pics how it’s routed” so I sent more pics actually the ones I’ve posted here. I described how it’s routed in the reply with the additional pics and that was three weeks ago and crickets no reply. I would rather not publicly bash the guy for the terrible customer service and incorrect work.
Should have talked to Tommy White. partshound.net. Tommy knows his stuff. He's been my reserve parachute :)
I might have a feeling who made your harness. I received a headlight harness, and it had an extra connector with a black wire ( to nowhere ). I never went back.
I would not have a problem if you outed him. You don't have say anything negative. It could help another forum member, to avoid a problem.
Personally, I've always had great luck with Evans wiring harnesses.
rbevans7@aol.com
Bill & Rose Evans*8835 Parson Rd*Erie,PA*16509
phone (814) 864-2622*fax (814) 866-8184
BTW.....do you still have the origional Carter AFB CARBS instead of the AVS II carbs? Just curious.
BOB RENTON
rbevans7@aol.com
BOB RENTON
No I don’t have the carbs wish i had them
though.
