Triplegreen500
- 10:07 AM
- Dec 3, 2020
- western Maryland
So...I started the inventory-disassembly last night (take stuff apart, figure out what's bad and what I need to order). Admittedly this project has been...back-burnered all summer and I've been slacking. But, it's time. MASSIVE camber changes at random while driving (like, VISIBLY toes-under about an inch from wheel top to wheel bottom). Something's worn, so it's time to replace it all.
Got the right front pretty much apart. Going to do one side at a time, so I have the "other" side as a reassembly template.
It's a 4-manual-drum car. I pulled the wheel and hub off. Pulled the complete brake assembly off and hung it by some wire from the fender braces. Shock is out. UCA is out. UCA bolts look....not entirely straight. They're gonna get replaced! Torsion adjuster bolt and plate are out - a vigorous dousing of PB, and it came right out. And that's where I stopped. I've never done a torsion bar suspension before so I wanted to do my research before just pulling on stuff. I read various posts, and looking at my bars I've got the standard 0.88" bars ('70 Charger 500, 318/904, a/c car). Also in posts I saw where some folks need a tool; some bars come out by hand. We shall see. I also saw mention of clips? I see the nut/washer/bushing setup where it passes through the LCA (nut is forward of the LCA at the front end of the bar); are the clips at the rear where it goes to the frame?
I have a copy of the Mopar shop manual on my tablet at home that I'll be referring to, but working in a shop every day I know there's the book way...and there's the real world, that can often (and safely) eliminate steps 3-28 in the book...so I figured I'd ask if anyone had any tips from here out?
My plan at this point is to look it over once the LCA is out, and decide if I want to get all-new, loaded arms, or just get new bushings for my existing bars. I'll likely get the Moog problem-solver offset UCA bushings; it's a cruiser, so I don't think I need to go as far as QA1 tubular UCAs (and it's 100% survivor so I don't really want to go modding stuff if I don't have to). I'll get new swaybar end links and bushings. New ball joints. Wheel bearings look fine, they'll just get a repack. I don't mind the 4 wheel drums, but maybe someday I'll go with discs (it has original 14" steelies which I know won't clear many disc setups)...but not worried about it right now.
I have a press.
I have a torch.
I have a balljoint fork.
Anyone have any suggestions? Anything I'm missing that I should order once I get the LCA out and see what condition it's in?
I have a press.
I have a torch.
