Found a Cool Vice/Anvil Combination
HawkRod
Formerly hsorman
Staff member
5:31 PM
Lansdale, PA
I found this cool combination vice / anvil at a neighbors house; it was laying in the basement all rusty and nasty looking. I've never seen anything like it!
It was patented in 1912, so I am assuming it was made maybe 1913-1919 timeframe?
After I cleaned it up it looks really decent. I will definitely give this a few more years of use!
My son dragged that exact same anvil/vice home from a shed he helped clean out this past spring. I cleaned it up and listed it on marketplace for him. Took a couple weeks, but we got $100 for it.
That’s pretty cool- some old vises and anvils can be worth some real money.
that was cheap
Cool find !
You know that will last with the quality from back then.
How heavy is it ?
It's not as heavy as it might look. The inside is hollowed out for the screw mechanism, so it is only a little bit heavier than a vice of about the same size. If you and going to pound some metal with it, you certainly need to bolt it down. The biggest issue I will have is that it does not have a swivel, so I may need to mount it on a stump or something so I can put metal on it from different angles.
that was cheap
Wow, well, then I feel good. I got it essentially free, as I bought a belt sander and it was thrown in on the deal.
Here is a shot underneath. The only thing I did was insert a washer to tighten up the mechanism a bit. It was a bit loose and sloppy but works perfectly now.
