Upper rear seat 67 GTX
Gus chiggins
12:27 PM
None
Does the upper rear seat in 1967 GTX, or Satellite just use a nut, and bolt to hold the seat frame to the floor pan mounting brackets ?
Yes, one bolt each side. The nut is built into the lower brackets. The hooks hold the upper seat frame.
There is no nut, hex head sheet metal screw. Need a photo?
Yes, a picture would work. i will need the bolts. Somebody on ebay wants $44.00 for the two screws, i'm sure i can find something comparable for way less. :)
That is actually ridiculous. If not complete restoration, go to some bolt supply place and you might get them for 10.00$. Many others screws from different application MOPARS will work.
That's what i told that guy. Those screws are not "rare". Just another ripoff.
I found them on escam for 4.95 for two. They are exactly like the screws that some guy wants $44.00 for. The ebay seller is Hoover auto parts. I have bought from Hoover before, no problems.
Hoover sucks in my experience. Never again. doesnt send a full order and then sez I lost the parts.
That's fine. I guess you can't goof an order for a couple of screws
