Camshaft help?
I would get bullet called very soon for December. For technical help we ask for Tim Goolsby, but I would guess anyone would know how far out they are w flat tappets. I think it's been hit n miss on cam cores.
I Will do that.... Thanks for all help....
I calling bullet! they was not sure if they make it before december! But 440 source has a 2 hyd flat tappet comp grind in stock but i have No idee about this Vs the 705 voodoo the grind is a ex295hl.
Advertised Intake Duration:295
Advertised Exhaust Duration:307
Intake Duration at .050 Inch Lift:251
Exhaust Duration at .050 Inch Lift:257
Intake Valve Lift:0.564
Exhaust Valve Lift:0.564
Lobe Separation:110
Exhaust Close ATDC:40
Intake Open BTDC:42
Exhaust Open BBDC:88
Intake Close ABDC:74
And ex285hl:
Advertised Intake Duration:285
Advertised Exhaust Duration:297
Intake Duration at .050 Inch Lift:241
Exhaust Duration at .050 Inch Lift:247
Intake Valve Lift:0.545
Exhaust Valve Lift:0.545
Lobe Separation:110
Exhaust Close ATDC:35
Intake Open BTDC:37
Exhaust Open BBDC:83
Intake Close ABDC:69
Sorry all this questions.. But a very few to ask about this here in Norway..
Stay with 705 over those two.. The bigger one probably will make a little more power but longevity is questionable. I don't think you will do any better for a hydraulic that what you have.
Bummer that Bullet is that far back. A few years back..they got us Cams in a week. Your right... Pickens are slim if you want it in december.
As far as a solids ready to ship:
Summit has a xtq solid grind available The XTQ would be quicker and make more power then the 705. I would rather have it on 110lsa though for what you are doing.
XTQ
COMP Cams 23-631-5 COMP Cams Drag Race Camshafts | Summit Racing
Could call crower...see how far out they are...may have one in stock? Not thrilled w what they offer though off the shelf, custom be likely same time as bullet.
Mopar/Dodge/Chrysler - Camshafts
Hi and thanks for all help i have to ask about dynamic compression with this 705.. We have pump gas like your 91 octane.. And My static compression Will be at 10.7 and if i use a calculator on this will the dynamic be 9.56 if i do this right... I have heard thats way to mutch on pump??? Any on this?
Sorry My fault i forgot to ad 15 degree on that @50 abdc number.... IT Will be 8.7:1...
I dont think your plugging in the correct numbers. To find a dcr use the seat timing, .050 number dcr doesn't mean much.
Look on your cam card for the seat timing. Advertised is 284, actual should be 287 for 705voodoo.
The voodoo is assymetric, meaning they close the intake valve 4-5 degrees later. So the number if it were not assymetric is 69.5. The actual should be about 73.5-74.5 (since it's assymetric).
Should be looking at a DCR in the mid 7's. Plug in your details. Wallace racing has a good site.
Learning something new evry day thanks
XTQ
Hi i can get this 631-5 comp CAM.. And they recomend the 925-16:
Max Lift:0.665
Installed Height:1.9
Coil Bind Height:1.175
O.D. of Outer:1.509
I.D. of Inner:0.697
I.D. of Outer:1.125
Spring Style:Dual
Spring Rate:395
Seat Pressure:111
Damper:Yes.
And My heads are with pac:
Number:
TFS-16893-50
Part Type:
Valve Springs
Product Line:
Trick Flow® by PAC Racing Dual Valve Springs
UPC:
842645100710
Valve Spring Style:
Standard
Number of Springs Per Valve:
Dual
Maximum Valve Lift (in.):
0.700 in.
Retainers Included:
No
Outside Diameter of Outer Spring (in.):
1.460 in.
Coil Bind Height (in.):
1.050 in.
Damper Spring Included:
No
Spring Rate (lbs/in.):
391 lbs./in.
Inside Diameter of Outer Spring (in.):
1.075 in.
Inside Diameter of Inner Spring (in.):
0.794 in.
Locks Included:
No
Valve Stem Seals Included:
No
Valve Springs Coated:
No
Quantity:
Sold as a set of 50.
Notes:
Up to .700 in. lift @ 1.875 installed height
Installed Height (in.):1.875 in.
Seat Pressure at Installed Height (lbs.):120 lbs.
Open Height (in.)(application):1.175 in.
Open Pressure (lbs.):394 lbs..
Do you think i need to swap this out with the comp Springs?
925 Looks like the same spring as what you already have. One suggestion install a .020 shim get the seat pressure around 130-140. Imo.. 120 isn't enough.
XTQ
Max Lift:0.665
O.D. of Outer:1.509
I.D. of Inner:0.697
I.D. of Outer:1.125
Spring Style:Dual
Spring Rate:395
Seat Pressure:111
Damper:Yes.
Number:
TFS-16893-50
Part Type:
Valve Springs
Product Line:
UPC:
842645100710
Valve Spring Style:
Standard
Dual
0.700 in.
Retainers Included:
No
1.460 in.
1.050 in.
No
391 lbs./in.
1.075 in.
0.794 in.
Locks Included:
No
No
No
Quantity:
Notes:
Thanks for all help i Will order up this.. So My friend can bring it over in his bag... Free shipping to Norway
The 440 I built last year had TF240 heads. I used 21st century beehive springs....
