Carb and timing
Duda
6:55 PM
Vandergrift Pa
I’m looking for someone or a shop that can help me with tuning on my 69 charger 440. I have a new carb on it and after it warns up and idles it likes to act like it’s running out of fuel or to much fuel. The motor does have a mild cam in it. The vacuum advance was bad so I replaced it. Now the motor won’t idle unless the vacuum is disconnected and plugged. i am reading that it does have to be disconnected on this site. I’m not happy with the timing either as this is another issue that just doesn’t convince me at 10. I live in the New Smyrna Beach Florida area if anyone can assist me. I won’t be in town till possibly Saturday.
Mark
Can you provide more detailed info like what carb, type of ignition, type of fuel pump, what rpm at idle, different settings you've tried, etc.
The carb is my 2nd new edelbrock I would have to look at the size, single point factory distributor with pertronix, new Hemi fuel pump, 1,000 rpm at idle. I had my two buddies help with all this and they both think it was fine but not for me, lol.
Once it's warmed up is the choke fully open? What port do you have the vac advance connected to? Have you checked how many degrees the distributor is advancing around 2500-3k? Once you know that, you can determine how much initial you can run.
10 degrees initial timing is pretty low. It will run but probably fall on its face when in gear. Id run that initial timing up to 14 to 16 degrees advanced. Then when you go find your total timing unplug the vacuum advance and plug the carb port. Run the engine at 2500 rpm for a second and check timing. If you want 32-36 degrees total timing at 2500 rpm. Do this by loosening the distributor bolt. Just enough to turn the distributor it wont take much to change the timing just make sure you have a good timing light. Once you get that dialed in you can then plug your advance back up to the carb. Then you want to tune the carb to maximum vacuum. Someone will chime in if I got something wrong.
I have a good writeup on tuning a mopar see below..
Tuning Resources | Exhaust Suggestions |
| Engine Swaps | Early Hemis | Back to Tech Links |
Tuning Tips
Keeping your engine tuned is beneficial in many ways. Not only does it reduce the burden on one's pocketbook in regards to fuel savings, but a good tuneup also reduces tailpipe emissions. Below is information you may find helpful in tuning your Dodge Truck.
This first article titled Timing is Everything was taken from HOT ROD Magazine's Brutally Basic Tech section of the April 1997 issue.
How to Set Ignition Timing
There are two things an engine must have; spark and fuel. The proper amount of fuel and air compressed at the ideal moment produces power. In this piece we deal with igniting the spark that lights the fire.
Ignition timing is typically split into three types. The first is ignition timing that is, the amount of spark lead that is set using a timing light (aimed at the harmonic balancer with the engine at idle). The second type is mechanical advance, determined by the distributor's mechanical advance system. The final type is vacuum advance, determined by the vacuum canister attached to the distributor. All three combine to produce the total amount of ignition timing in your engine at any given load and/or rpm.
Since a mechanical distributor is still the most popular form of ignition, we'll focus on it. But before we set these values, it's important to understand how these events interact. Initial advance is set by moving the distributor in the engine. Once initial timing is set, it's complemented by the mechanical and vacuum advance curves.
Mechanical advance adds additional timing to the engine and is based strictly on rpm. The mechanical advance weights and springs inside the distributor combine to produce a curve that begins with initial timing (with the engine at idle) and increases to a certain rpm, but generally peaks below 3,000 rpm. This is often referred to as the mechanical ignition curve.
Vacuum advance also adds timing to the engine, hut it is based on engine load and is controlled by intake manifold vacuum. When the throttle is partially open (highway cruising), manifold vacuum is high. This vacuum signal is routed to the distributor and "pulls" on the vacuum advance canister to create more ignition timing. As the throttle opening increases, load increases and manifold vacuum decreases. At wide open throttle (WOT), manifold vacuum is at or near zero and the vacuum advance produces no additional ignition timing.
Images from HOT ROD Magazine.
Now that we know how these three systems work, let's look at a real-world example. Our fictitious engine is a small-block V-8, any V-8, but these variables interact the same with all engines. Let's give the motor 8 degrees of initial timing, as observed with a timing light. A test on the distributor machine reveals 28 crankshaft degrees of total mechanical advance (at 2,800 rpm) and another 14 degrees of vacuum advance. By adding all three values, we can see that at 2,800 rpm at light throttle (14 inches or more of manifold vacuum), the engine has 50 degrees of total ignition advance. At WOT at 2,800 rpm, however, the engine only has 36 degrees of total timing (50 degrees minus 14 of vacuum advance).
The photos illustrate how to go about moving the distributor and setting the initial timing. By applying a timing tape to the harmonic balancer, for example, you can set initial timing with a standard timing light and check total timing as well. To check only initial plus mechanical advance, disconnect the vacuum advance.
Total timing requirements are dependent upon many variables. A typical street engine with a compression ratio of 9.0:1 runs very well with around 36 degrees of timing (initial plus mechanical) for a rough total of 15-55 degrees of timing at light throttle when vacuum advance is employed. If the engine detonates or pings under WOT reduce the timing. If it surges or pings at part throttle, reduce the amount of vacuum advance. Experimentation with timing can help performance, driveability, and mileage by customizing the ignition curve to your particular application. Don't be afraid to make changes. HR
Idling By is another article taken from the April 1997 issue of HOT ROD Magazine's Brutally Basic Tech section.
Idling By
How To Set Idle Mixture
Little things can make a big difference in how an engine performs. Street engines spend a lot of time at idle and off idle speeds, so on carbureted engines it’s important that the idle mixture be adjusted properly. This improves driveability, minimizes rough idle, and can provide cleaner emissions and better fuel economy. Here's a quick look at how to set Idle mixture on a stock or mildly modified engine.
All engines require an acceptable air/fuel ratio to run properly, even at idle. Stock or mildly tweaked engines generally idle at 16-18 inches of intake manifold vacuum between 750 and 900 rpm. Carburetors equipped with adjustable mixture screws allow the tuner to change the amount of fuel delivered to the engine creating an ideal idle mixture.
On most carburetors, turning the idle mixture screw clockwise leans the idle mixture. Turning the screws counter-clockwise richens the mixture, If there is a vacuum leak, it must be repaired before the idle mixture can be properly adjusted.
All stock engines specify a certain idle speed, but generally 800-850 rpm works well. Properly setting the idle mixture also creates the highest manifold vacuum, so a vacuum gauge makes the task easier. The best backyard procedure for setting idle mixture is the "idle speed drop" method. First, connect the vacuum gauge to the manifold. Adjust the idle mixture richer or leaner until the highest vacuum is read, once this is attained, turn the idle mixture screws leaner until the rpm begins to drop. then turn the screws richer a slight amount. The ideal idle mixture has now been set.
If you don't have a vacuum gauge, use a low-speed tachometer. The tach should have a low-scale readout that is sensitive to increments of at least 50 rpm. Use the tach to help you adjust the idle mixture screws evenly to create the highest idle speed. If the idle speed exceeds 900-950 rpm, use the idle speed screw to slow the engine down. then readjust the idle mixture.
This isn’t a difficult procedure but it can be tough if the engine has a big cam and low manifold vacuum. If the carburetor requires a large throttle blade opening, modifications will be necessary (see "Curing Holley Hiccups. HOT ROD, December '96). Otherwise, this is a simple procedure that anyone can do in a matter of minutes. HR
The location of the idle mixture screws varies with each carburetor. Most Holly four-barrel carbs locate the idle mixture screws on the metering block (A). On the other hand, Carter, Edelbrock, and other Weber-derived carburetors locate the mixture screws at the front of the carb (B).
Electronic Ignition
Have you added Electronic Ignition to your truck or purchased one fortunate to have it already? Listed here are the sections Basic Startup and Adjustment and Ignition Tuning for Maximum Performance taken directly from the Mopar Performance Small Block V-8 Electronic Ignition Kit instruction sheet and HTML formatted.
BASIC STARTUP AND ADJUSTMENT:
Note: The procedures outlined below are for tuning of the MP Ignition Conversion Kit on all vehicles and all ignition conversions.
TOOLS REQUIRED: Distributor wrench, timing light, 3/32" allen wrench.
Install new spark plugs gapped at .035".
Install spark plug wires. If you have fresh, high performance wires, it is okay to use them again. If your wires are more than two years old, it is strongly suggested to install a new set of high performance ignition wires. If reinstalling old wires, remove them from the old distributor cap one at a time and transfer them to the new cap and corresponding spark plug. If new wires are being installed, start with the number one wire in the same location as noted in step 3 (below) and work your way around, one at a time. The firing order on all Chrysler V8 engines is 1-8-4-3-6-5-7-2. The "A" engines (273-318-340-360) have clockwise distributor rotation. The "B" (361-383-400), "RB"(413-426W-440) engines and the 426 Hemi have counter-clockwise distributor rotation.
Image from actual instruction sheet.
Connect a timing light to the battery and #1 spark plug wire.
Check to make sure that the vaccum advance hose is still disconnected from the distributor. Temporarily plug the vaccum hose.
Start the engine. The ballast resistor may begin to smoke after the initial startup. This is normal, but the smoking should stop after the engine has run for a couple of minutes.
Set the initial timing at 5 +/- 2 degrees BTDC and tighten the distributor hold down bolt so that the distributor housing will not rotate. Recheck the timing setting to insure that the distributor did not move while being tightened. Reset the timing if necessary. Disconnect the timing light.
Leaving the vaccum hose disconnected and plugged, test the vehicle. After the engine is fully warmed up, make two or three throttle runs. the runs should be made in high gear if possible. If the engine does not have any detonation (spark knock), the initial timing setting is okay. If the engine does detonate, reduce the initial timing by 2 degrees. Rerun the full throttle test in high gear. Repeat this procedure until the engine does not detonate.
Once the initial timing setting has been completed, unplug and reconnect the vaccum hose to the distributor. With the vaccum hose connected, make two or three steady, part throttle runs. There should not be any detonation, surges or hesitation in the engine. If there is, the vaccum advance unit is adding too much advance to the spark curve. If so, with the engine turned off, disconnect the vaccum hose. Carefully insert a 3/32" allen wrench into the fitting where the vaccum hose was connected to the vaccum advance canister. You will be able to feel the allen wrench go into an internal allen screw used to adjust the amount of advance provided by the canister. Be careful not to puncture the diaphram inside the canister. With the allen wrench plugged into the adjusting screw, turn the allen wrench 1/2 turn (180 degrees) clockwise to reduce the vaccum advance by approximately two to three degrees. Remove the allen wrench, reconnect the vaccum hose and rerun the part throttle test. Repeat this procedure until the detonation, surging and/or stumbling is eliminated.
IGNITION TUNING FOR MAXIMUM PERFORMANCE: Tuning for maximum performance assumes the rest of the engine is also suitable for maximum performance. The octane rating of the fuel being usedmust be sufficient to accomidate the engine's compression ratio. The engine's harmonic balancer must have either degree marks or timing tape which correctly shows up to 60 degrees before top dead center. The carburetor must be properly jetted so that detonation or surging is not caused by the fuel mixture being too lean when the ignition is at maximum advance. The ignition coil and spark plug wires must be able to deliver sufficient spark to fire the plugs under maximum engine loading. If you are unsure about any of the above, consult the Mopar Performance Engine Modifications Manual. The manual outlines the proper ways to construct a race engine.
If the procedures outlined for maximum performance are followed and the engine begins to detonate, you must decrease the timing advances until the detonation is eliminated. Detonation not only severely reduces power, it also destroys pistons, rings and rod bearings. Do not run an engine that is detonating.
Tools required: Timing light, 3/32 allen wrench, vaccum gauge with long hose, vaccum source ("Mighty Vac"), and a friend or helper.
1. Set the basic timing for total mechanical spark advance.
Disconnect and plug the vaccum advance hose.
Connect timing light to the battery and and number 1 spark plug wire.
Loosen the distributor hold down clamp so the distributor housing may be rotated by hand.
Start the engine and allow it to warm up fully.
Set the idle speed between 2600 and 2800 RPM.
Set the timing according to the following chart:
Engine Heads Timing Specification
A Production - Pre '89 (Iron) 35 BTDC
A Production - '89 & Newer (Iron) 32 BTDC
A W2 (Iron) 35 BTDC
A W5 (Alum.) 35 BTDC
B/RB Production (Iron) 38 BTDC
B/RB Stage I, II, III, IV, V (Iron or Alum) 38 BTDC
B/RB Indy (Alum) 35 BTDC
B/RB B1 (Alum) Under 475 cu. in. 37-39 BTDC
B/RB B1 (Alum) Over 475 cu. in., Under 15.0:1 Ratio 36-38 BTDC
B/RB B1 (Alum) Over 475 cu. in., Over 15.0:1 Ratio 34-36 BTDC
B/RB B1 TS 34 BTDC
Hemi All (Iron or Alum) 35 BTDC
Tighten the distributor hold down bolt.
Reduce the idle to the original setting, unplug and reconnect the vaccum advance line.
2. Set the vaccum advance for total ignition advance.
After the basic timing has been set for total mechanical spark advance, disconnect the vaccum hose at the carburetor. Connect a vaccum gauge to the carburetor's vaccum advance port and route the gauge and hose into the passenger compartment of the vehicle. Place the gauge in a location where an assistant can read teh gauge while the vehicle is being operated.
With the vehicle in operation, note the maximum amount of vaccum generated by the engine while in gear and being held at a steady speed between 2000 and 4000 RPM.
Stop the vehicle, turn off the engine and connect a timing light to the battery and number 1 spark plug wire.
Start the engine, and raise the idle to 2600 RPM. Connect a vaccum source (Mighty Vac) to the distributor's vaccum canister and draw vaccum up until to the reading noted in step b.
Note the total advance shown on the harmonic balancer.
Total advance, mechanical plus vaccum, should be set according to the following chart:
Engine Total Advance
A 50 BTDC
B/RB 56 BTDC
Hemi 53 BTDC
Disconnect the vaccum source and insert a 3/32" allen wrench into the internal vaccum canister adjustment screw. Turn the allen screw (clockwise to decrease, counterclockwise to increase) to obtain the correct setting. Reconnect the vaccum souce and recheck the timing. Continue repeating this procedure until the correct setting is obtained.
Remove the timing light and vaccum source. Reconnect the vaccum advance hose. Reset the idle speed to your original setting.
Please Note: This page is intended as a guide, and is not guaranteed in any way. All info above is to the best knowledge of the author.
The choke is fully open when warm. We tried both ports with vacuum advance, I had it on the right side and my buddy said it should be on the left. I believe the total timing was at 35 degrees at 3000 rpm.
Tuning Tips
Idling By
Electronic Ignition
A W2 (Iron) 35 BTDC
B/RB B1 TS 34 BTDC
A 50 BTDC
B/RB 56 BTDC
Hemi 53 BTDC
I will need to review all this as it appears to be very informative.
thanks
The problem with tuning for ignition timing @ 2500-3000 RPM is if the dizzy has factory springs in it, the mechanical advance will NOT be all in until 4000-4500 RPM. This is even more important when running more initial advance like most of do. This is a chart from the Mopar Engines book.
Always get your timing dialed in before messing with carb adjustments.
Make sure no vacuum leaks, all ports in use or plugged on the carb and manifold. What is idle and low rpm vacuum value. A mentioned by other you need to know the arm stamp and springs inside the distributor. This will tell you what level of mechanical advance it will give and how fast. Early single point might be marked 12 which is 24 deg mechanical at the crank. Later stuff was 15 which gives you 30 and limits the amount of initial you can have unless you weld up the slot. But that is all top end, and your issue sounds like idle and off idle issues.
So it may get back to what type of vacuum signal you have at idle.
I would check for any type of vacuum leak(manifold,carb,etc) also you said you were using the factory points distributor with Petronix. Check the distributor bushing, if its worn, it causes all kinds of trouble. Check timing chain also for slop, that can make a difference too.
Make sure that you have some good high octane gas, or it wont run well at any rpm or temperature.
