OzCharger69
I'm seeking some help to troubleshoot my oil pressure problem. It's a reasonably fresh 383, Comp Cam (not sure which), stock oil pan, with maybe 2000 miles on it. I'm running a K&N filter and VR-1 10-40W oil. I have a Dakota Digital dash so any quick changes in oil pressure immediately shows on the dash.
Oil pressure is fine while driving around, it stays at 30-70 PSI depending on rpm. When engine is up to temp, the pressure will occasionally drop to zero when idling at the lights and picks up as soon as the car gets moving. This sudden drop to zero doesn't always happen at idle, but it definitely happens if I hard brake.
I'm start the troubleshoot with the following (in that order) -
1) Change the oil and put a Wix filter
2) Check the oil pressure relief valve
3) Check distributor shaft
4) Check oil pickup tube
5) Valve covers off to check for a dropped lifter
Any ideas on what else I should be checking?
