patbclc
Hi I'm looking for help identifying these rocker arms and push rods. I built motor over 20 years ago and forgot brand ad need to get at least a new push rod. It's in a stroker 400 block Thank you in advance
That's more of testament to the quality of the stuff!! Pushrods are off by a quarter inch??With that many threads showing I can’t believe that it took 20 years for an adjuster to break off… You will need to measure to get longer pushrods as it not a “combo” deal but what the actual numbers are..
Thank youWith that many threads showing I can’t believe that it took 20 years for an adjuster to break off… You will need to measure to get longer pushrods as it not a “combo” deal but what the actual numbers are..
Thank youMaybe check that lobe too
Thank youOrder push rods from smith brothers save yourself a lot of greif
Thank youThose rockers were made by Dove.
Marketed by Indy, and I think Hughes at one time.
No longer made.
Is the one pushrod bent?
If not, and the cup isn’t mangled.......you can probably just reset the adjuster screw and be good to go.
It’s not what you’re asking about, but those pushrods are way too short.
You can make estimations ... but really should be measured with a checker.. and then with a 5/16 ball in the cup, minus that divided on half. Effective lengthYes I took off and measured pushrods. About 8.25 tip to tip and .175 recess in cup. I had 4-6 threads showing below rocker arms. Isn't 1-2 normal? I figure 4/24 = .166 longer for pushrods? They are 3/8 with 5/16 ball. Are the measured tip to tip or tip to cup recess? Really appreciate the help. I'm thinking I need 8.25 + .166= 8.41 pushrods
