Glove Box Plunger Switch Hole Plug?
archangel
10:21 AM
Washington
'70 Super Bee. I am restoring back to factory original. My car did not come with A01 Light Group. The previous owner had installed some A01 items including the glove box light. I removed the plunger switch/lens and repaired the lens hole in the box.
Is there a plug that is supposed to fill the plunger switch hole or did non-A01 cars just have the open hole?
You could use a black body plug - one the same as the firewall tachometer .... 7/8" I think will fit.
Thank you. I think I will go with the open hole then.
A plug would not doubt look a lot better, not that I will be opening the glove box that much, but I am striving for OE look for better or worse.
