Nacho-RT74
- 11:40 PM
- Oct 8, 2012
- Valencia, España
72RoadrunnerGTX was faster than me on the reply about that 100 amps ammeter LOL. That kind of ammeter was used on earlier 70 Chryslers and mids 70s A/B bodies ( and of course on next bodies productions, F, M etc… ) to replace the regular Full load ammeters. They are a remote reading gauge by milivolts variation between both ends of an external shunt wire being part of the engine wiring on engine bay. The coil built into the gauge is somehow a magnetic amplifier to allow the larger move to the needle by the smaller current ammount.
The use of diff models/bodies ammeters on some diff car is physically posible while the gauge is built similar. I meant if is pointing up or down for example. The distance between studs is the same on all or almost all ammeters, but not the indexing. Some cars have a lateral reading, like E bodies and I think A body Rallye clusters. 71/74 B bodies got even two diff gauges for the Rallye clusters. If they are Clock/tach cluster ammeter needle points down. If regular Rallye cluster, ammeter is pointing up, like the standard cluster
About the non centered needle... I have dealt with couple of ammeters with needles like that, hence why I know why I’m talking about.
