318 block casting #'s = 318 race engine?
TAZZ
1:36 AM
Church Point La. (Lewisburg)
I was looking up the casting numbers on the 318 in my 74 Charger and found information on the net that ID'd the engine as a "race engine". Can anyone explain to me what that means?
Also if you want to know more about what you have look for a vin on your block. If it has one it was not aftermarket, it was oem born in a car.
Apparently at the time when they made the racing x blocks the external casting was the same as the production 318, thus they share the same casting number 4104230-318.
But on the racing block the internal casting contains the differences with thicker webbing and thicker cylinder walls and also has a x. Saying the 4104230 is a casting number for a racing block is correct, but also a incomplete statement....it also should have the X.
Do you have a link to the info so we can see what you’re seeing and reply accordingly? Otherwise, we’re at a disadvantage.
The late 60s truck 318 HD block is about all I've heard of as far as a block "to build for racing" as it were.
Notice the X cast in the Block. If no X its just a 318. The X block is supposedly up to 4.1 bore and considerably heavier. Check out the thick pan rails and main webs.
i think you could get them over the counter or thru the old DC catalog.
i dont think they were ever in a production vehicle?
i thought? they were originally designed for the circle track guys ?
That was the only way to get them or via mail order which was probably directly through the DC program. Perhaps PAW? IDK?
Correct, never in a production vehicle.
It was designed as a “Racing Block” period.
Circle track or drag, it doesn’t matter. The block and the W2 head were made for racing and promoted as racing but never did they say, circle track, nascar or drag.
I’ve had people say different but have never seen it in print or advertisement. Always “race.”
With the X.
